Saltar al contenido principal
Sony Handycam HDR-CX580V Battery Replacement
  1. Sony Handycam HDR-CX580V Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Battery Replacement: paso 2, imagen 1 de 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
Conclusión
To replace a new battery, simply snap the battery into the slot from which you removed it from.
Una persona más ha completado esta guía.
Joyelle Woodson
Miembro Desde 03/21/17
270 Reputación
2 Guías creadas
Equipo
Texas Tech, Team S46-G5, Bennett Spring 2017 Miembro de Texas Tech, Team S46-G5, Bennett Spring 2017
TTU-BENNETT-S17S46G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 22
Todo El Tiempo: 501
