Saltar al contenido principal
Sony Handycam HDR-CX380 Battery Replacement
  1. Sony Handycam HDR-CX380 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Battery Replacement: paso 2, imagen 1 de 1
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Battery Replacement: paso 3, imagen 1 de 2 Sony Handycam HDR-CX380 Battery Replacement: paso 3, imagen 2 de 2
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
Conclusión
To insert a new battery or reinsert the one you removed, simply follow step 3 in reverse order and rotate the camera as described in step 1.
Una persona más ha completado esta guía.
John Santoro
Miembro Desde 02/04/16
729 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-5, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G5
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 554
