Introducción
Use this guide to help you remove the broken or defected motherboard in your Sony Handycam HDR-Cx220.
Qué necesitas
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 Screwdriver to remove the 5mm screw
Use the Plastic Opening tools to unhook the highlighted area.
Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
Use the plastic opening tool to release the front hook.
Use the plastic opening tool to release the back hook.
Una persona más ha completado esta guía.
