Saltar al contenido principal
Sony Handycam HDR­-CX220 Buttons Replacement
Qué necesitas
  1. Sony Handycam HDR­-CX220 Buttons  Replacement, Battery: paso 1, imagen 1 de 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Buttons  Replacement: paso 2, imagen 1 de 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: paso 3, imagen 1 de 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: paso 3, imagen 2 de 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: paso 3, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Buttons  Replacement: paso 4, imagen 1 de 3 Sony Handycam HDR­-CX220 Buttons  Replacement: paso 4, imagen 2 de 3 Sony Handycam HDR­-CX220 Buttons  Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Buttons  Replacement: paso 5, imagen 1 de 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: paso 6, imagen 1 de 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: paso 6, imagen 2 de 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: paso 6, imagen 3 de 3
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  7. Sony Handycam HDR­-CX220 Buttons  Replacement: paso 7, imagen 1 de 2 Sony Handycam HDR­-CX220 Buttons  Replacement: paso 7, imagen 2 de 2
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
Conclusión
2 personas más completaron esta guía.
Keven
Miembro Desde 03/11/16
811 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Miembro de UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Miembros
12 Guías creadas
Un comentario
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 892
