Saltar al contenido principal
Sony Handycam FDR-AX33 Speaker Replacement
Qué necesitas
  1. Sony Handycam FDR-AX33 Speaker Replacement, Panel: paso 1, imagen 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement, Panel: paso 1, imagen 2 de 2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 Speaker Replacement: paso 2, imagen 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 2, imagen 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 Speaker Replacement: paso 3, imagen 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 Speaker Replacement: paso 4, imagen 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 Speaker Replacement: paso 5, imagen 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 5, imagen 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 5, imagen 3 de 3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 Speaker Replacement: paso 6, imagen 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 6, imagen 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 Speaker Replacement: paso 7, imagen 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 Speaker Replacement: paso 8, imagen 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 8, imagen 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 8, imagen 3 de 3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 Speaker Replacement, Speaker: paso 9, imagen 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement, Speaker: paso 9, imagen 2 de 2
    • Remove the two 4 mm Phillips #00 screws from the inside of the screen hinge.
    • Remove the black plastic from the back of the screen.
  10. Sony Handycam FDR-AX33 Speaker Replacement: paso 10, imagen 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 10, imagen 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: paso 10, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, unplug the speaker. The connector should be a white piece of plastic attached to a red wire and a black wire.
    • Remove the speaker with the black nylon spudger. The speaker is attached by adhesive.
Conclusión
Una persona más ha completado esta guía.
Lee Conway
Miembro Desde 01/24/19
184 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G2, White Winter 2019 Miembro de Cal Poly, Team S18-G2, White Winter 2019
CPSU-WHITE-W19S18G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 618
