Saltar al contenido principal
Sony Handycam DCR-SR42 Lens Replacement
Qué necesitas
  1. Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: paso 1, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Lens Replacement: paso 2, imagen 1 de 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Lens Replacement: paso 3, imagen 1 de 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Lens Replacement: paso 4, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement: paso 4, imagen 2 de 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Lens Replacement: paso 5, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement: paso 5, imagen 2 de 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Lens Replacement: paso 6, imagen 1 de 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Lens Replacement: paso 7, imagen 1 de 1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Lens Replacement, Internal Components: paso 8, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement, Internal Components: paso 8, imagen 2 de 2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Lens Replacement: paso 9, imagen 1 de 3 Sony Handycam DCR-SR42 Lens Replacement: paso 9, imagen 2 de 3 Sony Handycam DCR-SR42 Lens Replacement: paso 9, imagen 3 de 3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Lens Replacement: paso 10, imagen 1 de 3 Sony Handycam DCR-SR42 Lens Replacement: paso 10, imagen 2 de 3 Sony Handycam DCR-SR42 Lens Replacement: paso 10, imagen 3 de 3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 Lens Replacement: paso 11, imagen 1 de 3 Sony Handycam DCR-SR42 Lens Replacement: paso 11, imagen 2 de 3 Sony Handycam DCR-SR42 Lens Replacement: paso 11, imagen 3 de 3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Lens Replacement: paso 12, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement: paso 12, imagen 2 de 2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Lens Replacement: paso 13, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement: paso 13, imagen 2 de 2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Lens Replacement, Lens: paso 14, imagen 1 de 1
    • Remove the 3mm Phillips #00 screw from the underside of the camera near the lens housing.
  15. Sony Handycam DCR-SR42 Lens Replacement: paso 15, imagen 1 de 2 Sony Handycam DCR-SR42 Lens Replacement: paso 15, imagen 2 de 2
    • Use the plastic opening tool to pry the side casing off the camera.
  16. Sony Handycam DCR-SR42 Lens Replacement: paso 16, imagen 1 de 1
    • Remove the final 3mm #00 Phillips screw from the lens housing.
  17. Sony Handycam DCR-SR42 Lens Replacement: paso 17, imagen 1 de 1
    • Remove the lens housing from the camera.
  18. Sony Handycam DCR-SR42 Lens Replacement: paso 18, imagen 1 de 1
    • Remove the three 2mm Phillips #00 screws from around the lens.
  19. Sony Handycam DCR-SR42 Lens Replacement: paso 19, imagen 1 de 1
    • Remove the lens from the camera.
Conclusión
Una persona más ha completado esta guía.
Dan Muller
Miembro Desde 03/23/15
1,020 Reputación
5 Guías creadas
Equipo
Baylor, Team 7-13, Williams Spring 2015 Miembro de Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 786
