Saltar al contenido principal
Sony Handycam DCR-DVD103 Outer Cover Replacement
Qué necesitas
  1. Sony Handycam DCR-DVD103 Outer Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Outer Cover Replacement, Outer Cover: paso 3, imagen 1 de 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 4, imagen 1 de 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 4, imagen 2 de 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 5, imagen 1 de 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 6, imagen 1 de 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 6, imagen 2 de 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 7, imagen 1 de 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 7, imagen 2 de 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 8, imagen 1 de 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Outer Cover Replacement: paso 9, imagen 1 de 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
Conclusión
Una persona más ha completado esta guía.
kaitlin
Miembro Desde 01/11/11
342 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-44, Regan Winter 2011 Miembro de Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 17
Todo El Tiempo: 2,455
