Introducción
The CX260V has a very complicated process in having to take apart all of the external panels in order to access the internal speaker and other internal items.
Qué necesitas
Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
Using the screwdriver remove the two black 5mm screws located on the side of the speaker.
2 personas más completaron esta guía.
