Introducción
This guide will provide accurate steps in replacing the Camera Lens for the CX260V.
Qué necesitas
Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
Using the PH #00 size screw driver, unscrew one 5 millimeter screw located on the top left near the lens of the camera.
2 personas más completaron esta guía.
