Introducción
This guide will teach you how to replace the battery port on your Sony Handycam CX260V.
Qué necesitas
Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
Unplug the battery port connected to the frame/motherboard. Remove the battery port.
4 personas más completaron esta guía.
