Saltar al contenido principal
Sony Handycam CX260V Battery Port Replacement
Qué necesitas
  1. Sony Handycam CX260V Battery Port Replacement, Sony Handycam CX260V Housing Disassembly: paso 1, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
  2. Sony Handycam CX260V Battery Port Replacement: paso 2, imagen 1 de 1
    • Remove the two 5mm screws located on the top left and bottom of the camera.
    • Remove the 3mm screw located in the middle of the joint attaching the LCD screen to the device.
  3. Sony Handycam CX260V Battery Port Replacement: paso 3, imagen 1 de 1
    • Remove the two 5mm screws from the panel to the right of the LCD screen.
  4. Sony Handycam CX260V Battery Port Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to remove the cover for the recording buttons.
  5. Sony Handycam CX260V Battery Port Replacement: paso 5, imagen 1 de 1
    • Remove the five 5mm screws located on the bottom panel.
    • Remove the bottom panel covering the internal motherboard.
  6. Sony Handycam CX260V Battery Port Replacement: paso 6, imagen 1 de 1
    • Remove the 5mm screw located by the lens and two 5mm screws located under the handle.
    • Remove the leather strap from the device.
  7. Sony Handycam CX260V Battery Port Replacement: paso 7, imagen 1 de 1
    • Remove the 5mm screw to the left of the Record button.
    • Remove the entire right-side panel where the leather strap was located.
  8. Sony Handycam CX260V Battery Port Replacement: paso 8, imagen 1 de 1
    • Use a spudger to remove the LCD joint cover.
  9. Sony Handycam CX260V Battery Port Replacement: paso 9, imagen 1 de 2 Sony Handycam CX260V Battery Port Replacement: paso 9, imagen 2 de 2
    • Remove the three black 5mm screws and one silver 4mm screw located on the front right-side of the camera, near the orange motherboard.
    • The silver screw is located on the front right-side of the camera and is attached to the main panel.
  10. Sony Handycam CX260V Battery Port Replacement: paso 10, imagen 1 de 1
    • Remove the 5mm screw located on the top left near the camera lens.
  11. Sony Handycam CX260V Battery Port Replacement: paso 11, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, carefully detach the two wires connected to the bottom motherboard portion of the camera.
    • One white wire, one black wire, and one flat yellow wire are connected to the lens panel.
    • Remove the lens panel.
  12. Sony Handycam CX260V Battery Port Replacement: paso 12, imagen 1 de 1
    • Remove the three 5mm screws.
    • One is located at the bottom of the lens area, and the other two are on the top left and right of the lens area.
    • Carefully remove the camera lens with your hands or a spudger.
    • There are three springs located underneath the lens. Make sure to not lose them.
  13. Sony Handycam CX260V Battery Port Replacement: paso 13, imagen 1 de 1
    • Remove one 5mm screw located on the back left section near the zoom and picture control capturing button.
    • There are two flat blue wires keeping the buttons connected to the main assembly. Carefully set them aside or unplug them.
    • This partially removes the zoom and picture capturing control.
  14. Sony Handycam CX260V Battery Port Replacement: paso 14, imagen 1 de 1
    • Remove one silver 5mm screw located near the tripod mount.
    • Remove the tripod mount screw that has the mount assembly underneath.
  15. Sony Handycam CX260V Battery Port Replacement: paso 15, imagen 1 de 1
    • Remove the silver 5mm screw located on the front right side of the camera by the orange motherboard.
    • Unplug the wire.
    • Remove the silver 5mm screw underneath the wire.
  16. Sony Handycam CX260V Battery Port Replacement: paso 16, imagen 1 de 1
    • Using tweezers, release the clip attaching the main internal system to the mainframe. This allows the rest of the camera to be freely taken apart.
    • The side panel will have cords running through the frame. If you unplug these, the frame will be removable.
  17. Sony Handycam CX260V Battery Port Replacement, Battery Port: paso 17, imagen 1 de 2 Sony Handycam CX260V Battery Port Replacement, Battery Port: paso 17, imagen 2 de 2
    • Unplug the battery port connected to the frame/motherboard. Remove the battery port.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 306
