Saltar al contenido principal
Sony FDL-220R Watchman Button Replacement
Qué necesitas
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: paso 1, imagen 1 de 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: paso 1, imagen 2 de 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: paso 2, imagen 1 de 2 Sony FDL-220R Watchman Button Replacement, Remove screws: paso 2, imagen 2 de 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: paso 3, imagen 1 de 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: paso 3, imagen 2 de 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: paso 4, imagen 1 de 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: paso 4, imagen 2 de 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: paso 4, imagen 3 de 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: paso 5, imagen 1 de 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: paso 5, imagen 2 de 2
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
Conclusión
Sam Putnam
Miembro Desde 10/22/14
484 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-5, Williams Fall 2014 Miembro de Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 226
