Saltar al contenido principal
Sony FDL-220R Watchman Battery and Battery Contacts Replacement
Qué necesitas
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: paso 1, imagen 1 de 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: paso 1, imagen 2 de 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: paso 2, imagen 1 de 1
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: paso 3, imagen 1 de 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: paso 3, imagen 2 de 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: paso 4, imagen 1 de 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: paso 4, imagen 2 de 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: paso 5, imagen 1 de 1
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
Conclusión
Sam Putnam
Miembro Desde 10/22/14
484 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-5, Williams Fall 2014 Miembro de Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 494
