Saltar al contenido principal
Sony Ericsson z300 Screens Replacement
Qué necesitas
  1. Sony Ericsson z300 Screens Replacement, Back Phone Cover: paso 1, imagen 1 de 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Screens Replacement, Battery: paso 2, imagen 1 de 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Screens Replacement, Front Phone Cover: paso 3, imagen 1 de 1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Screens Replacement, Front Dark Grey Case: paso 4, imagen 1 de 1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Screens Replacement: paso 5, imagen 1 de 1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Screens Replacement: paso 6, imagen 1 de 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Screens Replacement, Screens: paso 7, imagen 1 de 1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Screens Replacement: paso 8, imagen 1 de 1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Screens Replacement: paso 9, imagen 1 de 2 Sony Ericsson z300 Screens Replacement: paso 9, imagen 2 de 2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Screens Replacement: paso 10, imagen 1 de 2 Sony Ericsson z300 Screens Replacement: paso 10, imagen 2 de 2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Screens Replacement: paso 11, imagen 1 de 1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
Conclusión
Alex Serventi
Miembro Desde 10/07/10
65 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 5-15, Maness Fall 2010 Miembro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,254
