Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide shows how to remove the Microphone.
Partes
No se especificaron partes.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. Slide the sim card out with your thumb.
    • Slide the sim card out with your thumb.
  4. To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  6. Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
  8. Use a plastic opening tool to lift up the brass colored panel.
    • Use a plastic opening tool to lift up the brass colored panel.
  9. Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  10. Work the plastic opening tool around the edges of the motherboard to release it from the clips.
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  11. Using a plastic opening tool lift up the keypad to remove it.
    • Using a plastic opening tool lift up the keypad to remove it.
  12. Use a plastic opening tool to lift the microphone out of its circular slot.
    • Use a plastic opening tool to lift the microphone out of its circular slot.
Conclusión
Alex Serventi
Miembro Desde 07/10/10
50 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 5-15, Maness Fall 2010 Miembro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,777
