Saltar al contenido principal
Introducción
This guide shows how to remove the Keypad.
Partes
No se especificaron partes.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. Slide the sim card out with your thumb.
    • Slide the sim card out with your thumb.
  4. To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  6. Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
  8. Use a plastic opening tool to lift up the brass colored panel.
    • Use a plastic opening tool to lift up the brass colored panel.
  9. Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  10. Work the plastic opening tool around the edges of the motherboard to release it from the clips.
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  11. Using a plastic opening tool lift up the keypad to remove it.
    • Using a plastic opening tool lift up the keypad to remove it.
Conclusión
Una persona más ha completado esta guía.
Alex Serventi
Miembro Desde 07/10/10
50 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 5-15, Maness Fall 2010 Miembro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,236
