Introducción
This guide shows how to remove the Front Speaker.
Qué necesitas
To remove the back cover, use your thumb to press down on the center of case and slide it off.
To remove the front cover, lift up the case with a fingernail in the small slot as shown.
To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
Use a plastic opening tool to lift the speaker out of its circular slot.
