Saltar al contenido principal
Sony Ericsson xPeria Active Speaker Replacement
Qué necesitas
  1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: paso 1, imagen 1 de 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: paso 1, imagen 2 de 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: paso 1, imagen 3 de 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: paso 2, imagen 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: paso 2, imagen 2 de 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: paso 3, imagen 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: paso 3, imagen 2 de 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Speaker Replacement, Unfastening The Motherboard Cover: paso 4, imagen 1 de 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: paso 5, imagen 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: paso 5, imagen 2 de 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Carefully pry the power cable away from the motherboard.
  7. Sony Ericsson xPeria Active Speaker Replacement: paso 7, imagen 1 de 1
    • Pry the motherboard out of the case.
  8. Sony Ericsson xPeria Active Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the power cable from the backside of the motherboard.
  9. Sony Ericsson xPeria Active Speaker Replacement: paso 9, imagen 1 de 1
    • The speaker can be seen in the top middle area on the reverse of the screen.
  10. Sony Ericsson xPeria Active Speaker Replacement: paso 10, imagen 1 de 1
    • Use the plastic opening tool to carefully pry the speaker away from the phone.
Conclusión
2 personas más completaron esta guía.
Daniel
Miembro Desde 10/13/14
437 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-5, Leahy Fall 2014 Miembro de USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 872
