Saltar al contenido principal
Sony Ericsson xPeria Active Screen Replacement
Qué necesitas
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: paso 1, imagen 1 de 3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: paso 1, imagen 2 de 3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: paso 1, imagen 3 de 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: paso 2, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: paso 2, imagen 2 de 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: paso 3, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement, Remove the battery: paso 3, imagen 2 de 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: paso 4, imagen 1 de 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: paso 5, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: paso 5, imagen 2 de 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: paso 6, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement, Screen: paso 6, imagen 2 de 2
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: paso 7, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement: paso 7, imagen 2 de 2
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: paso 8, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: paso 8, imagen 2 de 2
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: paso 9, imagen 1 de 2 Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: paso 9, imagen 2 de 2
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
Conclusión
5 personas más completaron esta guía.
Alex Tobin
Miembro Desde 10/06/14
406 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 14-5, Leahy Fall 2014 Miembro de USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Miembros
5 Guías creadas
Un comentario
hi can you add explain
abdnour master2 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,359
