Saltar al contenido principal
Sony Ericsson s710a SIM Card Replacement
  1. Sony Ericsson s710a SIM Card Replacement, SIM Card: paso 1, imagen 1 de 1
    • Slide the battery cover off by pushing it away from the camera side of the device.
    • This may require a good amount of force.
  2. Sony Ericsson s710a SIM Card Replacement: paso 2, imagen 1 de 1
    • Next remove the battery
    • Lift it out of the phone using the tab on the battery (marked in the image)
  3. Sony Ericsson s710a SIM Card Replacement: paso 3, imagen 1 de 1
    • The SIM card holder is now exposed (marked in image).
    • This will likely already have an existing SIM card in it if the phone has been previously used.
    • To open this, slide the holder upward (assuming the same orientation as in the image)
  4. Sony Ericsson s710a SIM Card Replacement: paso 4, imagen 1 de 1
    • The holder will then hinge open.
    • You are now able to insert a new SIM card.
  5. Sony Ericsson s710a SIM Card Replacement: paso 5, imagen 1 de 1
    • Insert the new SIM card in the orientation shown.
    • This is important, as the phone will not work if the metal contacts on the card are not properly aligned with the contacts on the phone.
  6. Sony Ericsson s710a SIM Card Replacement: paso 6, imagen 1 de 1
    • Now hinge the SIM card holder down so that it lays flat in the phone.
    • Slide the plastic holder downwards to lock it in place.
    • Now the battery and cover can be put back in place.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 1,860
