Saltar al contenido principal
Sony Ericsson s710a Motherboard Replacement
Qué necesitas
  1. Sony Ericsson s710a Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Motherboard Replacement: paso 2, imagen 1 de 1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a Motherboard Replacement: paso 3, imagen 1 de 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • Locate the four 6mm screws on the back of the phone.
    • Using a small Phillips head screwdriver, remove the four screws.
  5. Sony Ericsson s710a Motherboard Replacement: paso 5, imagen 1 de 2 Sony Ericsson s710a Motherboard Replacement: paso 5, imagen 2 de 2
    • Flip the phone over and slide it open.
    • Using the prying tool, remove the plastic piece covering the microphone.
    • Locate and remove the two 6mm screws located under the plastic piece and remove them using a small Phillips screwdriver.
  6. Sony Ericsson s710a Motherboard Replacement: paso 6, imagen 1 de 3 Sony Ericsson s710a Motherboard Replacement: paso 6, imagen 2 de 3 Sony Ericsson s710a Motherboard Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool to remove the black plastic cover from the rest of the phone.
    • It is best to start from the bottom of the phone by the memory card slot.
    • The cover should pop out of place by the four corners of the phone. There is no need to use excessive force as this may cause the plastic to break.
  7. Sony Ericsson s710a Motherboard Replacement: paso 7, imagen 1 de 1
    • Once the back cover is removed, remove the small black piece shown in the picture.
  8. Sony Ericsson s710a Motherboard Replacement: paso 8, imagen 1 de 1
    • Using the plastic opening tool, slide around the motherboard to loosen it.
    • Lift the motherboard up but not completely because in order to remove the motherboard you need to lift and pull it out.
  9. Sony Ericsson s710a Motherboard Replacement: paso 9, imagen 1 de 2 Sony Ericsson s710a Motherboard Replacement: paso 9, imagen 2 de 2
    • Using the plastic opening tool, separate the connectors to the screen.
    • Make sure to note the orientation and location of each cable before disconnecting. This will ensure that the motherboard will be reconnected properly.
    • Once the old motherboard is removed insert the new one if desired, and then reassemble the phone.
Conclusión
Mike
Miembro Desde 11/21/11
31 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,392
