Introducción
This guide will detail how to detach the two halves of the phone, remove the LCD screen, and gain access to the main control buttons.
Accessing this part of the phone will allow you to clean or replace any parts that are dirty or damaged.
Qué necesitas
Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
Remove the button and pad assembly as shown.
If desired, these items can now be cleaned or replaced.
Casi Terminas!
Conclusión
