Saltar al contenido principal
Sony Ericsson Z500a Logic Board Replacement
Qué necesitas
  1. Sony Ericsson Z500a Logic Board Replacement, Keypad: paso 1, imagen 1 de 3 Sony Ericsson Z500a Logic Board Replacement, Keypad: paso 1, imagen 2 de 3 Sony Ericsson Z500a Logic Board Replacement, Keypad: paso 1, imagen 3 de 3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Logic Board Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Logic Board Replacement: paso 3, imagen 1 de 1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
  4. Sony Ericsson Z500a Logic Board Replacement, Logic Board: paso 4, imagen 1 de 2 Sony Ericsson Z500a Logic Board Replacement, Logic Board: paso 4, imagen 2 de 2
    • Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  5. Sony Ericsson Z500a Logic Board Replacement: paso 5, imagen 1 de 2 Sony Ericsson Z500a Logic Board Replacement: paso 5, imagen 2 de 2
    • Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
Conclusión
Tim
Miembro Desde 04/20/10
15 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-12, Maness Spring 2010 Miembro de Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 1,661
