Saltar al contenido principal
Sony Ericsson Xperia X10 LCD Display Replacement
Qué necesitas
Resumen del Video
  1. Sony Ericsson Xperia X10 LCD Display Replacement, Logic Board: paso 1, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement, Logic Board: paso 1, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement, Logic Board: paso 1, imagen 3 de 3
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Sony Ericsson Xperia X10 LCD Display Replacement: paso 2, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 2, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 2, imagen 3 de 3
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Sony Ericsson Xperia X10 LCD Display Replacement: paso 3, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 3, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 3, imagen 3 de 3
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Sony Ericsson Xperia X10 LCD Display Replacement: paso 4, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 4, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 4, imagen 3 de 3
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
  5. Sony Ericsson Xperia X10 LCD Display Replacement, LCD Display: paso 5, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement, LCD Display: paso 5, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement, LCD Display: paso 5, imagen 3 de 3
    • Unstuck the Touchscreen flex cable from the LCD Display Frame.
    • Use only plastic tools for this operation to avoid damage to the cable.
    • You can use hot air to make the separation easier.
    • Disassemble the Home buttons flex cable & Plastic Bracket to release the Touchscreen Flex cable.
  6. Sony Ericsson Xperia X10 LCD Display Replacement: paso 6, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 6, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 6, imagen 3 de 3
    • Use a Plastic Pry or other plastic tool to separate the LCD Display with Frame from the Front Touchscreen Housing.
    • Do this carefully.
  7. Sony Ericsson Xperia X10 LCD Display Replacement: paso 7, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 7, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 7, imagen 3 de 3
    • Remove the Menu / Camera buttons flex cable.
    • Use again hot air and carefully unstick the LCD Display flex cable from the frame.
  8. Sony Ericsson Xperia X10 LCD Display Replacement: paso 8, imagen 1 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 8, imagen 2 de 3 Sony Ericsson Xperia X10 LCD Display Replacement: paso 8, imagen 3 de 3
Conclusión
ZFix
Miembro Desde 12/09/13
191,182 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,519 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,198
