Saltar al contenido principal
Sony Ericsson Xperia Play LCD Display Replacement
Qué necesitas
Resumen del Video
  1. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: paso 1, imagen 1 de 3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: paso 1, imagen 2 de 3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: paso 1, imagen 3 de 3
    • Remove the battery cover and the battery.
    • You have the 6x silver screws and 7x black screws and you can remove the rear bezel.
  2. Sony Ericsson Xperia Play LCD Display Replacement: paso 2, imagen 1 de 3 Sony Ericsson Xperia Play LCD Display Replacement: paso 2, imagen 2 de 3 Sony Ericsson Xperia Play LCD Display Replacement: paso 2, imagen 3 de 3
    • By using a plastic tool, disconnect the main flex cable connector. Be careful, near to the connector there are many small elements.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play LCD Display Replacement: paso 3, imagen 1 de 2 Sony Ericsson Xperia Play LCD Display Replacement: paso 3, imagen 2 de 2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play LCD Display Replacement: paso 4, imagen 1 de 3 Sony Ericsson Xperia Play LCD Display Replacement: paso 4, imagen 2 de 3 Sony Ericsson Xperia Play LCD Display Replacement: paso 4, imagen 3 de 3
    • Unscrew the 4x black screws.
    • Remove the black sticker on the corner and disconnect the touchscreen flex cable.
    • Disassemble front bezel.
  5. Sony Ericsson Xperia Play LCD Display Replacement: paso 5, imagen 1 de 3 Sony Ericsson Xperia Play LCD Display Replacement: paso 5, imagen 2 de 3 Sony Ericsson Xperia Play LCD Display Replacement: paso 5, imagen 3 de 3
    • Use the thin side of a plastic tool to separate the LCD display from the base bezel.
    • Now you are ready to install the new spare part.
    • I prefer to test the new spare part before the full assembly.
  6. Sony Ericsson Xperia Play LCD Display Replacement: paso 6, imagen 1 de 1
Conclusión
3 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
192,056 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,525 Guías creadas
Un comentario
Do you have a datasheet for the display? I wanted to reuse it but i cannot find the function of the pins.
jp r - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 35
Todo El Tiempo: 5,104
