Saltar al contenido principal
Sony Ericsson Xperia Play Battery Replacement
Qué necesitas
  1. Sony Ericsson Xperia Play Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the phone around so the screen is facing a flat surface.
  2. Sony Ericsson Xperia Play Battery Replacement: paso 2, imagen 1 de 1
    • To remove the cover, use plastic removal tool on the seam of the case.
    • Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
  3. Sony Ericsson Xperia Play Battery Replacement: paso 3, imagen 1 de 1
    • After the “click” noise, lift the cover with your finger.
    • Do not puncture the battery. This can result in a fire.
  4. Sony Ericsson Xperia Play Battery Replacement: paso 4, imagen 1 de 1
    • Proceed with removing the battery by lifting the battery with a small plastic pry tool.
    • Use a plastic tool for safety. If a plastic tool is not available use your fingers.
  5. Sony Ericsson Xperia Play Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the device.
  6. Sony Ericsson Xperia Play Battery Replacement: paso 6, imagen 1 de 1
    • Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
  7. Sony Ericsson Xperia Play Battery Replacement: paso 7, imagen 1 de 1
    • Lightly press the battery into the phone so that it is secure.
  8. Sony Ericsson Xperia Play Battery Replacement: paso 8, imagen 1 de 1
    • To put the cover back on, apply force until a "click" sound is heard.
Conclusión
Pieter Boersma
Miembro Desde 03/25/15
371 Reputación
3 Guías creadas
Equipo
Un comentario
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
waytodawn0 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 1,553
