Saltar al contenido principal
Sony Ericsson W810I Vibration Cell Replacement
Qué necesitas
  1. Sony Ericsson W810I Vibration Cell Replacement, Battery: paso 1, imagen 1 de 1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Vibration Cell Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Vibration Cell Replacement: paso 3, imagen 1 de 2 Sony Ericsson W810I Vibration Cell Replacement: paso 3, imagen 2 de 2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Sony Ericsson W810I Vibration Cell Replacement, Case: paso 4, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement, Case: paso 4, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement, Case: paso 4, imagen 3 de 3
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson W810I Vibration Cell Replacement: paso 5, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 5, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 5, imagen 3 de 3
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
  6. Sony Ericsson W810I Vibration Cell Replacement: paso 6, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 6, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 6, imagen 3 de 3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
  7. Sony Ericsson W810I Vibration Cell Replacement: paso 7, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 7, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 7, imagen 3 de 3
    • Run the plastic opening tool upwards along that side, removing the housing.
  8. Sony Ericsson W810I Vibration Cell Replacement, Key Pad: paso 8, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement, Key Pad: paso 8, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement, Key Pad: paso 8, imagen 3 de 3
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
  9. Sony Ericsson W810I Vibration Cell Replacement: paso 9, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 9, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 9, imagen 3 de 3
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
  10. Sony Ericsson W810I Vibration Cell Replacement: paso 10, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 10, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 10, imagen 3 de 3
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
  11. Sony Ericsson W810I Vibration Cell Replacement, LCD Screen: paso 11, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement, LCD Screen: paso 11, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement, LCD Screen: paso 11, imagen 3 de 3
    • Remove the indicated 6.35mm screws with a Torx T6 screwdriver.
  12. Sony Ericsson W810I Vibration Cell Replacement: paso 12, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 12, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 12, imagen 3 de 3
    • Pull LCD screen gently out and the to side. Do not attempt to pull it completely away from the board below it.
    • Push up on the underside of the cable at the point of attachment with a plastic opening tool to detach it. The screen can now be separated.
  13. Sony Ericsson W810I Vibration Cell Replacement, Motherboard: paso 13, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement, Motherboard: paso 13, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement, Motherboard: paso 13, imagen 3 de 3
    • Using a plastic opening device, push against the underside of the brown portion of the the ribbon cable to unplug it.
  14. Sony Ericsson W810I Vibration Cell Replacement: paso 14, imagen 1 de 1
    • Using a plastic opening device, separate the top of the motherboard from the rest of the plastic casing.
  15. Sony Ericsson W810I Vibration Cell Replacement: paso 15, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 15, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 15, imagen 3 de 3
    • Pull forwards slightly on the motherboard so that it starts to fall out of the casing.
    • Thread the ribbon cable through the hole in the motherboard so that it does not become caught.
  16. Sony Ericsson W810I Vibration Cell Replacement, Vibration Cell: paso 16, imagen 1 de 1
    • This is the vibration cell. It causes the phone to vibrate when the vibrate setting is active.
  17. Sony Ericsson W810I Vibration Cell Replacement: paso 17, imagen 1 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 17, imagen 2 de 3 Sony Ericsson W810I Vibration Cell Replacement: paso 17, imagen 3 de 3
    • Insert the spudger into the crack between the green rubber container and the plastic case and pry it out. When the cell it is about halfway out, remove the spudger.
    • Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out.
Conclusión
Lucy Bowen
Miembro Desde 09/01/11
449 Reputación
7 Guías creadas
Equipo
Cuesta, Team 1-7, Zipperian Fall 2011 Miembro de Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Miembro
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,687
