Saltar al contenido principal
Sony Ericsson W810I LCD Screen Replacement
Qué necesitas
  1. Sony Ericsson W810I LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I LCD Screen Replacement: paso 3, imagen 1 de 2 Sony Ericsson W810I LCD Screen Replacement: paso 3, imagen 2 de 2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Sony Ericsson W810I LCD Screen Replacement, Case: paso 4, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement, Case: paso 4, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement, Case: paso 4, imagen 3 de 3
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson W810I LCD Screen Replacement: paso 5, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 5, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 5, imagen 3 de 3
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
  6. Sony Ericsson W810I LCD Screen Replacement: paso 6, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 6, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 6, imagen 3 de 3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
  7. Sony Ericsson W810I LCD Screen Replacement: paso 7, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 7, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 7, imagen 3 de 3
    • Run the plastic opening tool upwards along that side, removing the housing.
  8. Sony Ericsson W810I LCD Screen Replacement, Key Pad: paso 8, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement, Key Pad: paso 8, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement, Key Pad: paso 8, imagen 3 de 3
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
  9. Sony Ericsson W810I LCD Screen Replacement: paso 9, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 9, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 9, imagen 3 de 3
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
  10. Sony Ericsson W810I LCD Screen Replacement: paso 10, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 10, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 10, imagen 3 de 3
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
  11. Sony Ericsson W810I LCD Screen Replacement, LCD Screen: paso 11, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement, LCD Screen: paso 11, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement, LCD Screen: paso 11, imagen 3 de 3
    • Remove the indicated 6.35mm screws with a Torx T6 screwdriver.
  12. Sony Ericsson W810I LCD Screen Replacement: paso 12, imagen 1 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 12, imagen 2 de 3 Sony Ericsson W810I LCD Screen Replacement: paso 12, imagen 3 de 3
    • Pull LCD screen gently out and the to side. Do not attempt to pull it completely away from the board below it.
    • Push up on the underside of the cable at the point of attachment with a plastic opening tool to detach it. The screen can now be separated.
Conclusión
2 personas más completaron esta guía.
Lucy Bowen
Miembro Desde 09/01/11
449 Reputación
7 Guías creadas
Equipo
Cuesta, Team 1-7, Zipperian Fall 2011 Miembro de Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Miembro
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 4,301
