Saltar al contenido principal
Sony Ericsson W518a Camera Lens Replacement
Qué necesitas
  1. Sony Ericsson W518a Camera Lens Replacement, Faceplate: paso 1, imagen 1 de 1
    • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
  2. Sony Ericsson W518a Camera Lens Replacement: paso 2, imagen 1 de 3 Sony Ericsson W518a Camera Lens Replacement: paso 2, imagen 2 de 3 Sony Ericsson W518a Camera Lens Replacement: paso 2, imagen 3 de 3
    • Insert your plastic opening tool into the notch.
    • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
    • When enough of the faceplate has been lifted it can be easily removed.
    • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
  3. Sony Ericsson W518a Camera Lens Replacement, Camera Lens: paso 3, imagen 1 de 1
    • Remove the four 2mm Phillips screws from the back housing of the phone.
  4. Sony Ericsson W518a Camera Lens Replacement: paso 4, imagen 1 de 3 Sony Ericsson W518a Camera Lens Replacement: paso 4, imagen 2 de 3 Sony Ericsson W518a Camera Lens Replacement: paso 4, imagen 3 de 3
    • Insert the plastic opening tool in the notch at the top corner of the phone.
    • Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
  5. Sony Ericsson W518a Camera Lens Replacement: paso 5, imagen 1 de 2 Sony Ericsson W518a Camera Lens Replacement: paso 5, imagen 2 de 2
    • Remove the lends by pushing the lens from the inside of the housing.
Conclusión
Una persona más ha completado esta guía.
kgkramer
Miembro Desde 06/27/12
121 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 1-5, Regan SU 2012 Miembro de Cal Poly, Team 1-5, Regan SU 2012
CPSU-REGAN-SU12S1G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,152
