Saltar al contenido principal
Sony Ericsson W300i Main Screen Replacement
Qué necesitas
  1. Sony Ericsson W300i Main Screen Replacement, Main Screen: paso 1, imagen 1 de 2 Sony Ericsson W300i Main Screen Replacement, Main Screen: paso 1, imagen 2 de 2
    • Here is the phone in question: The Sony Ericsson W300i.
    • To access the interior of the phone, you need the a plastic opening tool, and a T6 Torx screwdriver.
  2. Sony Ericsson W300i Main Screen Replacement: paso 2, imagen 1 de 3 Sony Ericsson W300i Main Screen Replacement: paso 2, imagen 2 de 3 Sony Ericsson W300i Main Screen Replacement: paso 2, imagen 3 de 3
    • Before removing the screen, you must first remove the battery.
    • Remove the battery cover by applying pressure while sliding the base cover away from the phone and then lifting the cover up.
  3. Sony Ericsson W300i Main Screen Replacement: paso 3, imagen 1 de 3 Sony Ericsson W300i Main Screen Replacement: paso 3, imagen 2 de 3 Sony Ericsson W300i Main Screen Replacement: paso 3, imagen 3 de 3
    • Using your fingers, lift the end of the battery up and then pry the battery from the phone base.
    • During reassembly you must reinsert the battery so the gold markings are at the top of the battery.
  4. Sony Ericsson W300i Main Screen Replacement: paso 4, imagen 1 de 3 Sony Ericsson W300i Main Screen Replacement: paso 4, imagen 2 de 3 Sony Ericsson W300i Main Screen Replacement: paso 4, imagen 3 de 3
    • This step may take a few minutes.
    • Remove the front plate off the phone with a plastic opening tool to gain access to the screws beneath.
    • Use the point indicated on the photo as a good prying point.
    • Use a moderate amount of force.
    • Be aware of the sharp edges of the prying tool.
  5. Sony Ericsson W300i Main Screen Replacement: paso 5, imagen 1 de 2 Sony Ericsson W300i Main Screen Replacement: paso 5, imagen 2 de 2
    • Use the T6 Torx screwdriver to remove the four screws.
    • Place screws in a safe location to avoid losing them.
  6. Sony Ericsson W300i Main Screen Replacement: paso 6, imagen 1 de 3 Sony Ericsson W300i Main Screen Replacement: paso 6, imagen 2 de 3 Sony Ericsson W300i Main Screen Replacement: paso 6, imagen 3 de 3
    • Use a plastic opening tool to separate the screen cover from the top half of the phone.
    • Slide the corner of the opening tool along the side of the phone toward the bottom corner.
    • With the phone screen facing away from you, press into the screen crevice at an angle so that the tool pushes away towards the main screen.
    • Once the seal has been broken, tug the cover away.
  7. Sony Ericsson W300i Main Screen Replacement: paso 7, imagen 1 de 3 Sony Ericsson W300i Main Screen Replacement: paso 7, imagen 2 de 3 Sony Ericsson W300i Main Screen Replacement: paso 7, imagen 3 de 3
    • Use your fingers to pry the plug end of the orange ribbon cable away from the screen.
    • Remove screen.
  8. Sony Ericsson W300i Main Screen Replacement: paso 8, imagen 1 de 2 Sony Ericsson W300i Main Screen Replacement: paso 8, imagen 2 de 2
    • Using the new screen, reattach the plug end of the orange ribbon cable.
    • Push new screen into the phone.
Conclusión
Reassemble the phone following the steps in reverse.
3 personas más completaron esta guía.
Michael Faist
Miembro Desde 02/17/16
178 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-2, Garvin Spring 2016 Miembro de Ohio State, Team 1-2, Garvin Spring 2016
OSU-GARVIN-S16S1G2
3 Miembros
4 Guías creadas
Un comentario
nicely done, no fuss, no jargon, nice and clear and simple ...and it worked :D
Jim O - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 836
