Saltar al contenido principal
Sony Ericsson W300i Camera Replacement
Qué necesitas
  1. Sony Ericsson W300i Camera  Replacement, Camera: paso 1, imagen 1 de 2 Sony Ericsson W300i Camera  Replacement, Camera: paso 1, imagen 2 de 2
    • The tools you will need for this step is the prying tool and the T6 Torx screwdriver.
  2. Sony Ericsson W300i Camera  Replacement: paso 2, imagen 1 de 3 Sony Ericsson W300i Camera  Replacement: paso 2, imagen 2 de 3 Sony Ericsson W300i Camera  Replacement: paso 2, imagen 3 de 3
    • Remove the back cover of the phone by pushing downwards with your thumbs.
  3. Sony Ericsson W300i Camera  Replacement: paso 3, imagen 1 de 2 Sony Ericsson W300i Camera  Replacement: paso 3, imagen 2 de 2
    • Now, remove the battery from the phone by gently prying the battery out.
  4. Sony Ericsson W300i Camera  Replacement: paso 4, imagen 1 de 2 Sony Ericsson W300i Camera  Replacement: paso 4, imagen 2 de 2
    • Remove the front plate from the phone by using the prying tool.
  5. Sony Ericsson W300i Camera  Replacement: paso 5, imagen 1 de 2 Sony Ericsson W300i Camera  Replacement: paso 5, imagen 2 de 2
    • You now have access to the fours screws that hold the front of the phone together. Remove the four screws.
  6. Sony Ericsson W300i Camera  Replacement: paso 6, imagen 1 de 2 Sony Ericsson W300i Camera  Replacement: paso 6, imagen 2 de 2
    • Use the prying tool to separate the two parts of the top of the phone
  7. Sony Ericsson W300i Camera  Replacement: paso 7, imagen 1 de 3 Sony Ericsson W300i Camera  Replacement: paso 7, imagen 2 de 3 Sony Ericsson W300i Camera  Replacement: paso 7, imagen 3 de 3
    • Use your fingers to remove the screen and unplug the ribbon cable from the bottom right corner of the back of the screen.
  8. Sony Ericsson W300i Camera  Replacement: paso 8, imagen 1 de 2 Sony Ericsson W300i Camera  Replacement: paso 8, imagen 2 de 2
    • Now you have access to the camera, which is the silver plate at the bottom of the phone. Remove the camera and replace with a new camera.
Conclusión
Laura Inbody
Miembro Desde 02/19/16
7 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-2, Garvin Spring 2016 Miembro de Ohio State, Team 1-2, Garvin Spring 2016
OSU-GARVIN-S16S1G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 341
