Introducción
Replacing a faulty LCD is relatively simple, just be patient and gentle while replacing the screen.
Slide the battery cover up and off the phone.
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
Undo the metal clip on each side of the core using the plastic opening tool.
2 personas más completaron esta guía.
