Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Replacing the keypad requires that the front case be removed.
Partes
  1. Slide the battery cover up and off the phone. Slide the battery cover up and off the phone.
    • Slide the battery cover up and off the phone.
  2. Pop the battery out of its slot by lifting it up. Pop the battery out of its slot by lifting it up.
    • Pop the battery out of its slot by lifting it up.
  3. Insert the plastic opening tool in between the front case and the back case. Apply downward pressure to make the case lift upwards, thus popping the front case off. Use caution when removing the front case. It may seem stuck but just ease it out.
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case. Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
    • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 14-10, Forte Winter 2011 Miembro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Miembros
16 Guías creadas
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
Janos Lazar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 5,279
