Introducción
This guide provides instruction for installing a screen for the Sony Ericsson TM506 cell phone.
Qué necesitas
Firmly hold the phone between your fingers with your thumb on the battery cover.
Push down with your thumb until the battery cover comes off.
The sound box is attached to the case by two snap hooks.
Lift the sound box up to remove it from the case.
Locate the 80-pin connector.
Carefully, lift up on the connector to separate it from the board.
Pull apart the screen and the case at one end. Then slide the screen out to completely detach them.
Una persona más ha completado esta guía.
