Saltar al contenido principal
Sony Ericsson T68i Logic Board Replacement
Qué necesitas
  1. Sony Ericsson T68i Logic Board Replacement, Keypad: paso 1, imagen 1 de 2 Sony Ericsson T68i Logic Board Replacement, Keypad: paso 1, imagen 2 de 2
    • Remove the battery from the back.
  2. Sony Ericsson T68i Logic Board Replacement: paso 2, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement: paso 2, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement: paso 2, imagen 3 de 3
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Logic Board Replacement: paso 3, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement: paso 3, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement: paso 3, imagen 3 de 3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Logic Board Replacement: paso 4, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement: paso 4, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement: paso 4, imagen 3 de 3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Logic Board Replacement, Screen: paso 5, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement, Screen: paso 5, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement, Screen: paso 5, imagen 3 de 3
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  6. Sony Ericsson T68i Logic Board Replacement: paso 6, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement: paso 6, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement: paso 6, imagen 3 de 3
    • Remove the board and screen.
  7. Sony Ericsson T68i Logic Board Replacement: paso 7, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement: paso 7, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement: paso 7, imagen 3 de 3
    • Carefully remove the plastic clips holding the screen on the board.
  8. Sony Ericsson T68i Logic Board Replacement, Logic Board: paso 8, imagen 1 de 3 Sony Ericsson T68i Logic Board Replacement, Logic Board: paso 8, imagen 2 de 3 Sony Ericsson T68i Logic Board Replacement, Logic Board: paso 8, imagen 3 de 3
    • Remove the plate protecting the more delicate processing parts from the logic board.
Conclusión
Tim Dascomb
Miembro Desde 04/13/10
159 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 26-34, Regan Spring 2010 Miembro de Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,077
