Saltar al contenido principal
Sony Ericsson K750i Keypad Replacement
Qué necesitas
  1. Sony Ericsson K750i Keypad Replacement, Back Casing: paso 1, imagen 1 de 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  2. Sony Ericsson K750i Keypad Replacement: paso 2, imagen 1 de 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  3. Sony Ericsson K750i Keypad Replacement: paso 3, imagen 1 de 1
    • Remove the casing to expose the camera's components.
  4. Sony Ericsson K750i Keypad Replacement, Keypad: paso 4, imagen 1 de 1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  5. Sony Ericsson K750i Keypad Replacement: paso 5, imagen 1 de 1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  6. Sony Ericsson K750i Keypad Replacement: paso 6, imagen 1 de 2 Sony Ericsson K750i Keypad Replacement: paso 6, imagen 2 de 2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
Conclusión
Abby Evers
Miembro Desde 10/04/11
202 Reputación
6 Guías creadas
Equipo
UW Stout, Team 1-6, Zhou Fall 2011 Miembro de UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,254
