Saltar al contenido principal
Sony Ericsson J22Oi Screen Replacement
Qué necesitas
  1. Sony Ericsson J22Oi Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Screen Replacement: paso 2, imagen 1 de 1
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Screen Replacement: paso 3, imagen 1 de 1
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Screen Replacement: paso 4, imagen 1 de 1
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Locate the five screws indicated on the phone.
  6. Sony Ericsson J22Oi Screen Replacement: paso 6, imagen 1 de 1
    • Use a T5 Screwdriver and unscrew the five screws.
  7. Sony Ericsson J22Oi Screen Replacement: paso 7, imagen 1 de 1
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  8. Sony Ericsson J22Oi Screen Replacement: paso 8, imagen 1 de 1
    • Now gently pull metal cover off.
  9. Sony Ericsson J22Oi Screen Replacement: paso 9, imagen 1 de 1
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  10. Sony Ericsson J22Oi Screen Replacement: paso 10, imagen 1 de 1
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
Conclusión
Una persona más ha completado esta guía.
James Au
Miembro Desde 10/06/12
10 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-36, Regan Fall 2012 Miembro de Cal Poly, Team 6-36, Regan Fall 2012
CPSU-REGAN-F12S6G36
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 481
