Saltar al contenido principal
Sony ECM-MS907 Volume issue troubleshooting
  1. Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: paso 1, imagen 1 de 2 Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: paso 1, imagen 2 de 2
    • Often when using the recording range of 90 degrees, a low recording occurs. This particular setting seems tailored towards a much louder object, such as a musical instrument, etc.
    • To change this setting, change switch to the 120 degree recording range.
  2. Sony ECM-MS907 Volume issue troubleshooting: paso 2, imagen 1 de 1
    • Another problem involves the stereo jack of the microphone being inserted into the wrong output of the external device.
  3. Sony ECM-MS907 Volume issue troubleshooting: paso 3, imagen 1 de 2 Sony ECM-MS907 Volume issue troubleshooting: paso 3, imagen 2 de 2
    • In this particular external device, the Sony MiniDisc player, the microphone stereo jack can mistakenly be inserted into the laptop, or "white" input.
    • Always remember to insert stereo jack into the microplug, or "red" input.
  4. Sony ECM-MS907 Volume issue troubleshooting: paso 4, imagen 1 de 1
    • Some volume issues could be related to other external devices, such as a laptop. This particular microphone was not designed to be used with a computer.
  5. Sony ECM-MS907 Volume issue troubleshooting: paso 5, imagen 1 de 1
    • One solution is to use a device such as a USB soundcard, which can be purchased online or at most electronics stores.
    • Simply insert soundcard into a USB input in the laptop
    • Insert stereo jack of microphone into the soundcard input marked with the "microphone" symbol.
    • This may resolve laptop related problems related to low volume during recordings.
Conclusión
Justin Lewis
Miembro Desde 01/23/14
242 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 1,160
