Saltar al contenido principal
Sony Dream Machine ICF-C717PJ Battery Replacement
Qué necesitas
  1. Sony Dream Machine ICF-C717PJ Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To start, use a small phillips screwdriver, to remove the screw located on the battery component on the back of the device.
  2. Sony Dream Machine ICF-C717PJ Battery Replacement: paso 2, imagen 1 de 2 Sony Dream Machine ICF-C717PJ Battery Replacement: paso 2, imagen 2 de 2
    • Once you have removed the screw from the battery cover, pull out the cover using your fingers.
  3. Sony Dream Machine ICF-C717PJ Battery Replacement: paso 3, imagen 1 de 1
    • Remove the remaining screws from the back of the clock.
    • Set them aside for reassembly
  4. Sony Dream Machine ICF-C717PJ Battery Replacement: paso 4, imagen 1 de 2 Sony Dream Machine ICF-C717PJ Battery Replacement: paso 4, imagen 2 de 2
    • Remove the back panel of the clock, pry open with screwdriver if necessary.
    • Ensure that the red wires connecting the back panel and the main device are not frayed or damage before proceeding to the next step.
Conclusión
Una persona más ha completado esta guía.
Equipo
UW Tacoma, Team S1-G3, Liner Summer 2018 Miembro de UW Tacoma, Team S1-G3, Liner Summer 2018
UWT-LINER-SU18S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 1,944
