Saltar al contenido principal
Sony Dream Machine ICF-C180 Speaker Replacement
Qué necesitas
  1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
  2. Sony Dream Machine ICF-C180 Speaker Replacement: paso 2, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 2, imagen 2 de 2
    • Wedge a plastic opening tool between the face of the clock and the body.
    • Pry open the face of the clock away from the body.
  3. Sony Dream Machine ICF-C180 Speaker Replacement: paso 3, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 3, imagen 2 de 2
    • To open the top casing, pull it upward.
    • Be careful not to yank on the ribbon cable when pulling on the top casing.
  4. Sony Dream Machine ICF-C180 Speaker Replacement: paso 4, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 4, imagen 2 de 2
    • Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
  5. Sony Dream Machine ICF-C180 Speaker Replacement: paso 5, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 5, imagen 2 de 2
    • Desolder the wires going to the speaker with a soldering iron.
  6. Sony Dream Machine ICF-C180 Speaker Replacement: paso 6, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 6, imagen 2 de 2
    • Use the plastic opening tool to remove the glue from the speaker.
  7. Sony Dream Machine ICF-C180 Speaker Replacement: paso 7, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 7, imagen 2 de 2
    • Loosen the speaker from the remaining glue with a plastic opening tool.
    • Insert the plastic opening tool into the rail that holds the speaker and push down.
  8. Sony Dream Machine ICF-C180 Speaker Replacement: paso 8, imagen 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: paso 8, imagen 2 de 2
    • Pull the speaker upward to remove it.
Conclusión
Una persona más ha completado esta guía.
Caleb John
Miembro Desde 05/31/16
101 Reputación
1 Guía escrita
Un comentario
HEY! that's moderately adequate...
Caleb John - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 509
