Saltar al contenido principal
Sony DVP-FX730 Screen Replacement
Qué necesitas
  1. Sony DVP-FX730 Screen Replacement, Monitor: paso 1, imagen 1 de 2 Sony DVP-FX730 Screen Replacement, Monitor: paso 1, imagen 2 de 2
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: paso 2, imagen 1 de 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: paso 3, imagen 1 de 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: paso 4, imagen 1 de 2 Sony DVP-FX730 Screen Replacement: paso 4, imagen 2 de 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: paso 5, imagen 1 de 2 Sony DVP-FX730 Screen Replacement: paso 5, imagen 2 de 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: paso 6, imagen 1 de 1
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: paso 7, imagen 1 de 1
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: paso 8, imagen 1 de 1
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: paso 9, imagen 1 de 1
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: paso 10, imagen 1 de 1
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: paso 11, imagen 1 de 1
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: paso 12, imagen 1 de 2 Sony DVP-FX730 Screen Replacement: paso 12, imagen 2 de 2
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: paso 13, imagen 1 de 2 Sony DVP-FX730 Screen Replacement: paso 13, imagen 2 de 2
    • Place your hand on the front of the screen and push upwards.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 11-21, Maness Winter 2012 Miembro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,714
