Saltar al contenido principal
Sony DVP-FX730 Monitor Replacement
Qué necesitas
  1. Sony DVP-FX730 Monitor Replacement, Cover: paso 1, imagen 1 de 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: paso 2, imagen 1 de 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: paso 3, imagen 1 de 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: paso 4, imagen 1 de 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: paso 5, imagen 1 de 2 Sony DVP-FX730 Monitor Replacement, Monitor: paso 5, imagen 2 de 2
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: paso 6, imagen 1 de 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: paso 7, imagen 1 de 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: paso 8, imagen 1 de 2 Sony DVP-FX730 Monitor Replacement: paso 8, imagen 2 de 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: paso 9, imagen 1 de 2 Sony DVP-FX730 Monitor Replacement: paso 9, imagen 2 de 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: paso 10, imagen 1 de 1
    • The screen should now be completely separated from the main device.
Conclusión
Andrew Ward
Miembro Desde 01/20/12
93 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-21, Maness Winter 2012 Miembro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,994
