Saltar al contenido principal
Sony DVP-FX730 Cover Replacement
Qué necesitas
  1. Sony DVP-FX730 Cover Replacement, Cover: paso 1, imagen 1 de 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: paso 2, imagen 1 de 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: paso 3, imagen 1 de 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: paso 4, imagen 1 de 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
Conclusión
Rogelio Garcia
Miembro Desde 01/20/12
19 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-21, Maness Winter 2012 Miembro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 1,456
