Qué necesitas
Move side panel to get access to screws
Remove two screws (black 2.5mm) with PH #0 screwdriver
Carefully remove the gold ribbons from the ports of the motherboard by lifting the gray tabs and pulling away the ribbon
You may want to use tweezers to remove the gold ribbons as a more delicate and safe approach, but this is not required
Carefully remove the last gold ribbon by lifting the gray tab and sliding out the ribbon.
4 personas más completaron esta guía.
