Saltar al contenido principal
Sony DSC-RX100MA Image Sensor Replacement
Qué necesitas
  1. Sony DSC-RX100MA Image Sensor Replacement, Back Cover: paso 1, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement, Back Cover: paso 1, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Image Sensor Replacement: paso 2, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 2, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 2, imagen 3 de 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Image Sensor Replacement: paso 3, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 3, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 3, imagen 3 de 3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Image Sensor Replacement: paso 4, imagen 1 de 2 Sony DSC-RX100MA Image Sensor Replacement: paso 4, imagen 2 de 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Image Sensor Replacement: paso 5, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 5, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 5, imagen 3 de 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Image Sensor Replacement: paso 6, imagen 1 de 2 Sony DSC-RX100MA Image Sensor Replacement: paso 6, imagen 2 de 2
    • Remove the back cover
  7. Sony DSC-RX100MA Image Sensor Replacement, Screen: paso 7, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement, Screen: paso 7, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement, Screen: paso 7, imagen 3 de 3
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
  8. Sony DSC-RX100MA Image Sensor Replacement: paso 8, imagen 1 de 2 Sony DSC-RX100MA Image Sensor Replacement: paso 8, imagen 2 de 2
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA Image Sensor Replacement: paso 9, imagen 1 de 2 Sony DSC-RX100MA Image Sensor Replacement: paso 9, imagen 2 de 2
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
  10. Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: paso 10, imagen 1 de 2 Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: paso 10, imagen 2 de 2
    • Using the Philips Screwdriver, remove the screw (black 3mm) located on the copper casing.
  11. Sony DSC-RX100MA Image Sensor Replacement: paso 11, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 11, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 11, imagen 3 de 3
    • Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
    • Remove casing.
  12. Sony DSC-RX100MA Image Sensor Replacement: paso 12, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 12, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 12, imagen 3 de 3
    • Using the Philips screwdriver, remove the three (silver 3mm) screws
    • Remove the screw (silver 2mm) from the upper right hand corner
  13. Sony DSC-RX100MA Image Sensor Replacement: paso 13, imagen 1 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 13, imagen 2 de 3 Sony DSC-RX100MA Image Sensor Replacement: paso 13, imagen 3 de 3
    • Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
    • Give it a little wiggle and you should feel the SD card holder come out.
  14. Sony DSC-RX100MA Image Sensor Replacement: paso 14, imagen 1 de 1
    • Now you can remove the marked gold ribbon cable from the SD card holder.
    • Utilize extreme caution while removing because the ribbon cables are extremely fragile and important to the camera.
Conclusión
Una persona más ha completado esta guía.
Isaiah De Leon
Miembro Desde 01/29/17
418 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 21-1, Maness Winter 2017 Miembro de Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 36
Todo El Tiempo: 2,998
