Saltar al contenido principal
Sony DSC-RX100MA Back Cover Replacement
Qué necesitas
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Back Cover Replacement: paso 2, imagen 1 de 3 Sony DSC-RX100MA Back Cover Replacement: paso 2, imagen 2 de 3 Sony DSC-RX100MA Back Cover Replacement: paso 2, imagen 3 de 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Back Cover Replacement: paso 3, imagen 1 de 3 Sony DSC-RX100MA Back Cover Replacement: paso 3, imagen 2 de 3 Sony DSC-RX100MA Back Cover Replacement: paso 3, imagen 3 de 3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Back Cover Replacement: paso 4, imagen 1 de 2 Sony DSC-RX100MA Back Cover Replacement: paso 4, imagen 2 de 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Back Cover Replacement: paso 5, imagen 1 de 3 Sony DSC-RX100MA Back Cover Replacement: paso 5, imagen 2 de 3 Sony DSC-RX100MA Back Cover Replacement: paso 5, imagen 3 de 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Back Cover Replacement: paso 6, imagen 1 de 2 Sony DSC-RX100MA Back Cover Replacement: paso 6, imagen 2 de 2
    • Remove the back cover
Conclusión
Una persona más ha completado esta guía.
KC Egger
Miembro Desde 02/10/17
291 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-1, Maness Winter 2017 Miembro de Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 26
Todo El Tiempo: 2,982
