Introducción
Disassemble the camera to get to the lens.
Remove the battery. Unscrew the three screws that are circled. Repeat for circled screws on either side. These screws are all the same size.
With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
Then lift the LCD display away from the camera and again carefully remove two ribbon cables (boxed in blue) and place aside.
6 personas más completaron esta guía.
