Saltar al contenido principal
Sony DCR-DVD 108 Motherboard Replacement
Qué necesitas
  1. Sony DCR-DVD 108 Motherboard Replacement, Sony DCR-DVD 108 Case Disassembly: paso 1, imagen 1 de 1
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Motherboard Replacement: paso 4, imagen 1 de 1
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Motherboard Replacement: paso 5, imagen 1 de 2 Sony DCR-DVD 108 Motherboard Replacement: paso 5, imagen 2 de 2
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 Sony DCR-DVD 108 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
    • Be careful not to bend the ribbon cables.
    • There is a hidden wire on the bottom of the board that should also be removed.
  7. Sony DCR-DVD 108 Motherboard Replacement: paso 7, imagen 1 de 3 Sony DCR-DVD 108 Motherboard Replacement: paso 7, imagen 2 de 3 Sony DCR-DVD 108 Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove 3 brown copper screws. Each copper screw has a #0 Phillips head and is 2.8mm in length.
  8. Sony DCR-DVD 108 Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift the motherboard up from the outside edges to remove.
Conclusión
In order to reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Elijah DeWolf
Miembro Desde 02/09/16
577 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 7-6, Cheng Spring 2016 Miembro de USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 626
