Introducción
The lens allow for clear and consistent previews for what you are filming. Thus image quality can be compromised if either lens is compromised; maintenance of this component easy yet critical.
Qué necesitas
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
Take the half of camera containing both lens components and turn front portion towards you.
Remove the four 4.3mm Phillips #0 screws pictured.
In order to reassemble your device, follow these instructions in reverse order.
