Saltar al contenido principal
Sony DCR-DVD 108 Front and Back Lens Replacement
Qué necesitas
  1. Sony DCR-DVD 108 Front and Back Lens Replacement, Sony DCR-DVD 108 Case Disassembly: paso 1, imagen 1 de 1
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 2, imagen 1 de 1
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 3, imagen 1 de 1
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 4, imagen 1 de 1
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 5, imagen 1 de 2 Sony DCR-DVD 108 Front and Back Lens Replacement: paso 5, imagen 2 de 2
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Front and Back Lens Replacement, Front and Back Lens: paso 6, imagen 1 de 1
    • Take the half of camera containing both lens components and turn front portion towards you.
    • Remove the four 4.3mm Phillips #0 screws pictured.
  7. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 7, imagen 1 de 1
    • Remove front lens and inspect for "dirt," smudges. or scratches. Use discretion, if lens appears too damaged, replace part.
  8. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 8, imagen 1 de 1
    • Gently pull lens housing to expose housing channel.
  9. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 9, imagen 1 de 1
    • With the pointed end of a plastic spudger, press latch located on the side of rear lens housing.
  10. Sony DCR-DVD 108 Front and Back Lens Replacement: paso 10, imagen 1 de 2 Sony DCR-DVD 108 Front and Back Lens Replacement: paso 10, imagen 2 de 2
    • Once loosened gently pull and remove lens housing. The lens should now be free to inspect and replace.
Conclusión
In order to reassemble your device, follow these instructions in reverse order.
Elijah DeWolf
Miembro Desde 02/09/16
577 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 7-6, Cheng Spring 2016 Miembro de USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 20
Todo El Tiempo: 383
